What spark plugs should I use for my SR20-DET?
bagnasco
Car: 1990 Nissan 240SX
I want to upgrade my sparkplugs. I've been looking at Bosch Platinum +2. But I started talking to friends and they told me to buy the NGK Iridium IX.
What does everyone else think? Bosch Platinums? NGK Iridiums? Or something else?
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
BKR7EIX NGk's if you are making less than 300whp, BKR8's if you are making 300-400whp and 15-20psi of boost, BKR9's if you are running over 20psi and more than 400whp. I run 8 heat range year round and have no problem.
S14toRPS13
Go with NGK. I believe most people do. I'm running about 18 psi on mine right now and I'm using BKR8's also.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Bosch plugs really only work well in german cars. Well,l atleast work the best from what I've seen.
Kalypso
ngk iridium
( though race teams use copper plugs all day )
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
kentuckyslider wrote:BKR7EIX NGk's if you are making less than 300whp, BKR8's if you are making 300-400whp and 15-20psi of boost, BKR9's if you are running over 20psi and more than 400whp. I run 8 heat range year round and have no problem.
240SXMOTORING.COM wrote:NGK Iridium IX Plug BKR8EIX *set of 4* - high HP applications
Set of 4,
2 steps colder spark plugs for SR20DET, KA24DE, CA18, all RB motors.
These are not recommended for daily use.
Use for High Horsepower cars that either run lots of boost or lots of timing!!!!
Helps lower combustion Temps.
So you're saying that if it's over 300hp then you should use 8s but 240sxmotoring.com states that they shouldn't be used for daily use.
*sorry for bumping an old thread...
PyR0NiAk
this question is bugging me... someone please answer???
S14toRPS13
It's fine. I normally just warm my car up for about 5 minutes before I drive if it's been driving for a long time. You can't just jump in and drive off like what a lot of people do in the mornings.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
dont use any spark plugs
PyR0NiAk
91SilviaKs wrote:dont use any spark plugs
AWESOME IDEA!!! I'll do it!!
tunermt
Car: s13 ka-t running AEM EMS v1, Gallant VR4 Running AEM EMSv2, S2k waiting for the Haltech
Stumbled on this old thread while searching for SR20det Iridium plugs and thought i'd share a little guide for other SR20det owners in need of upgraded plugs/coils or anyone dealing with spark blow out. https://ffrides.com/sr20det-ngk-iridium-spark-plugs/
tunermt
I personally run the bkr7eix-11 in my s14 Sr20det on e85 and 19psi. (R35 coils)
tunermt
OEM heat range:
Iridium core BKR6eix spark plugs
Copper core BKR6e spark plugs
1 step colder (common for modified SR20det 350-450hp range)
Iridium core BKR7eix
Copper core BKR7e
Expanding on my last post:
"I run BKR7eix in my personal SR20det (16G turbo, 19psi on E85)" The iridium core plugs work great and last 3-4 times as long as the copper core plugs. (i've also ran BKR6E, BKR7E and BKR8E) but prefer the iridium core as the copper cores just don't last long before they suffer from spark blowout. Nothing worse than not being able to run full boost because you're blowing out spark!!!
tunermt
https://youtu.be/0cdt65IIX3g
[youtube]0cdt65IIX3g[/youtube]
tunermt
Sorry for the bad youtube share in the post above, just noticed what was causing the video to no show up so fixed it here:
