Nismo400R33GTR »
https://forums.nicoclub.com/nismo400r33gtr-u42301.html
Tue Jul 28, 2009 5:13 pm
Tools needed:9-13 mm sockets and wrenches with extensions.Pliers for the hose clamps.flat head and Philips screw drivers.some duct tape.a band aid. 90% of you will bust open your knuckle, i did!
ok here we go.
first thing you do is show the motor just how much you hate it!
ok for real now. first thing i like to do is remove the hood, it allows you way more space to work and helps with lighting. removing the hood is as easy as simply removing the front bolts from each side first with a socket wrench, then remove the bottom 2 bolts from passenger and driver side. the last bolt you will want to hold the back of the hood with your free hand to avoid the hood slamming into the windshield and cracking it
as you can see my motor bay had a fire in it and like most motor bays it's dirty! simply grab an air hose and blow the crap out so you can see what your doing
there now it's a bit less nasty to work around in.
WARNING!!!! DISCONNECT THE BATTERY!!!!! this is important! any time your under the hood working on this kinda thing, safety first!!!!!!!! no need getting knocked on your butt...
ok i like to start from the front and work my way back on these pulls, first removing the intake to get at stuff we need under it. there are just a couple of these screws to remove from the above the radiator....
then start disconnecting sensors attached to the filter housing...
there are many of these hose clamps in the motor so for you noobs, to remove them simply place a wrench or pliers over the taps, push them together and slide the clamp down the hose.
disconnect the hose after the clamp is off...
now all these hoses and wires are exposed for us to work with under the intake. so simply follow the wires and hoses and disconnect them from what they are attached to...
now this is not needed on all swaps but my radiator was busted so it needed to go, (plus an new one with the sr20 should be done anyways), so as you can see in the picture if you disconnect the hose shove a rag in the hose and tape it with duct tape so you don't spill fluid all over the place, i only had masking tape so i made do... you should do this to all hoses you pull the contain fluid.
popping the radiator is simple there's only 4 of these bolts, two on top and two half way down, a hose on top a return hose on bottom and a breather on the bottom, disconnect and POP! out she comes.
as you can see, we now have a nice clean area where we can work in and around without headaches.
ok now what i like to do is start at the END of the harness and work my way to the fire wall. the last connections are behind this black box..
so simply pop the clips off like so..
the way to remove these Nissan clips is to place a screw driver on the taps and push inwards, they will spring off!.
the way a harness is ran is, the end is at the driver side strut tower, start is by the passenger side strut tower runs kinda clockwise if you will...
keep following the harness all the way around the block, disconnecting all the injectors as you go, you'll follow the chain of disconnects to the back of the fire wall where you'll notice the wires tucked behind your lines, there's only 3 clamps holding those back there so just pop em free and pull the now completely disconnected harness threw those lines and out by the fire wall, for now leave it connected to the ECU, we will cover that later. (in the picture this is an optional pull, as im replacing everything, im pulling all the pumps and accessory's.
now that you have the harness free we can start on the hardware!!!
.......next I'll go over removing the motor and trany from the drive shaft and pulling that bad boy OUT!!!
to be continued.
Modified by Nismo400R33GTR at 3:52 AM 7/29/2009
