sr20det install step by step
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
It's much easier to leave the transmission attached to the motor and take them out as 1 unit.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Agreed!
Nismo400R33GTR
Car: 1991 240sx HB s13.5
well then pyro why dont you make a step by step and leave mine alone?
PyR0NiAk
Nismo400R33GTR wrote:well then pyro why dont you make a step by step and leave mine alone?
are you seriously getting butt hurt because i gave you some advice? You'll have to change the bellhousing to use ka transmission so it needs pulled anyways. Also, you're going to want to swap the clutch while it's all apart. (It just makes sense) If you're trying to make a swap guide and can't handle some constructive criticism or some advice then I don't see this guide turning out very well. But while I'm at it, it also makes guides MUCH easier to read if you put all the pics and instructions in the original post (click edit) instead of in replies... The replies tend to confuse people as they have to search through the thread to find the info they need.
Also, there are several 8mm bolts in the engine bay. In your "tools needed" section, you only included 9-13
Modified by PyR0NiAk at 9:26 AM 7/29/2009
Nismo400R33GTR
well actually the entire trany is getting pulled because it's an automatic and auto's suck, but not everyone has to pull em, so since this is a guide im going to show HOW to pull it...k?
PyR0NiAk
Nismo400R33GTR wrote:well actually the entire trany is getting pulled because it's an automatic and auto's suck, but not everyone has to pull em, so since this is a guide im going to show HOW to pull it...k?
Please tell me WHO doesn't need to pull a KA transmission if they're swapping in a SR20...
