sr20det in a 93 civic coupe?
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
nismo066069
Car: NISSAN 1989 240SX
has any one have any information if it is possiable to put a 1991 nissan sr20det in a 93 honda civic any info please let me know it seems like a fun project but i was wondering if anybody have any suggestion on how to do it and what type linkages,brackets,hoses so if you have any info please help.
nametakennow
Car: '06 MINI Cooper S
Are you serious?
Anything is possible with enough time and money. Is this a RWD or FWD SR?
My brain hurts.
S13Teddy
Car: R32 Skyline, S13
I'm pretty sure you'd have to custom fabricate everything.
If its a FWD SR20 I think it might be kinda cool. Finally a Honda with some balls.
OriginalWheelman
Car: '15 Ford Focus Electric
S13Teddy wrote:custom fabricate
Ah those two words. They mean welders, plate steel, TIME, and lots of head scratching. And if you plan to get it running, circuit diagrams and wire cutters.
KDashy
Car: '97 Nissan 240SX
Haha, linkages brackets and hoses.
Least of your concerns.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
hahaha
hahahaha
I cant help it
Its not worth it, even if you do get it to work, some D-bag a$$ will steal them, because they are worth a premium right before race wars.
honda_killer240
Car: 90 Piggy coupe
SideWays=smiles wrote: because they are worth a premium right before race wars.
classic
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
honda_killer240 wrote: classic
X2
blindsnyper
Car: 2007 versa
what the fu....
are you f*cking reta....
are you seri....
i giveup your dumb
Dattebayo
Here's an idea...
Swap the subframe from a similar year CR-V into your Civic and then do a RWD SR swap using a S chassis cross-member and custom driveshaft. It sure would be a sleeper, but then again, it would cost a few thousand to get it all done...
blindsnyper
Car: 2007 versa
Dattebayo wrote:Swap the subframe from a similar year CR-V into your Civic..
ya since the crv was first mad in '96 and the civic is a '93
Dattebayo
My bad, I guess I'm an idiot because no one has tried it before (they have)
themadscientist
one of the fster CRXs was RWD with a 4G63. I am sure it can be done; much like tickling the back of your throat through your ***.
Dattebayo
themadscientist wrote:like tickling the back of your throat through your ***.
I know this girl that does this well. She is my soulmate!
ka24boos13t
Car: 91 300zx tt
Fwd sr in a civic?
I think it was be bad as hell.
Rwd sr in a civic?
Meh, two much work for the outcome.
Yeah the Fwd sr would take alot of work as well but I just can't see making someone thats not rwd...rwd. Just get a 240 in that case. Same damn thing.
Chezchs
Car: 1995 Zenki S14
OR! you could make yourself a Nonda Pulvic!
Here is a picture of the Nonda Pulvic in it's natural environment.
Nissan Pulsar + Honda Civic! If I had a Pulsar GTI-R and that civic sitting infront of me, I could probably think of a few things....
That is what I would do my friend. Get a front cut Pulsar SR20 F.O.B, some beer (probably a bad idea), Plasma cutter, and a mig welder! AND JUST GO NUTS! Then of course you'll have everything at your finger tips. If you pull this off...
oh and... >>>> WHY!
nametakennow
We get this question in the FWD SR forum once every couple months. It always goes like this.
It has been done, at least I think it has, but it's really not worth the time when there are plenty of good Honda engines that swap in far more easily.
Dattebayo
Chezchs wrote:
That really doesn't look like a Pulsar front end.
(edit: Somebody did a real shi.tty job re-sizing that pic...)
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Dattebayo wrote:(edit: Somebody did a real shi.tty job re-sizing that pic...)
Ahahahaha rofl
Chezchs
Car: 1995 Zenki S14
I did it with paint in 20 minutes. That's the front of a JDM nissan pulsar GTI-R (SR20) It's a 4WD car from japan, it's a 4WD. They go real fast! In a straight line.
Off topic Can I put 2003 Sentra SE-R Spec V rims on my 240 coupe?? Cause I found some real purdy ones.
Night shift at a hotel on a stormy night... you do things to entertain yourself.
nametakennow
Pulsar GTi-Rs are actually quite good in the corners too thanks to Nissan's AWD system...
As for the SE-R wheels, yes, but the offset isn't exactly optimal and they're only 7in wide.
Dattebayo
Chezchs wrote: I did it with paint in 20 minutes. That's the front of a JDM nissan pulsar GTI-R (SR20) It's a 4WD car from japan, it's a 4WD. They go real fast! In a straight line.
We are aware of the GTiR, thank you I believe you have a Sunny front end there though. And what's with this straight line crap? 2 posts in and you are already at max fail.
Chezchs
Car: 1995 Zenki S14
I may be a n00b. Paint sucks not me!
As for the rims, after much hunting! I'm new to Nissan's I'm aware of the bolt pattern, yes they will line up, but are they going to rub? J7 is all you need with an un-tuned KA24 with lots of bolt on-s I mean I was going to go with some Falken Hanabi's 17x7.5 offset was 38+ I believe, but those would look so niiiice plus they are in front of my face... and if I'm not mistaken they only weight 17lbs!
Modified by Chezchs at 6:28 AM 11/12/2007
danielekfuj
Car: miata, rocket ship
WHY?
nametakennow
Rubbing isn't the issue, it's that you can fit a LOT more wheel and rubber in there. 17X7 +45 (I think, may be +42 or +47) is a terrible setup for a 240.
17X7.5 +38 would be crap too. Head to the suspension forum and take a look around, you have a lot more options.
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
they fit... if you turn the steering wheel all the way to left / right the tires rub the struts if you have stock suspension. im talking about stock spec v tires on them. had em on my s13 hatch back in the day. sits reallie high.. gives you the "All-Wheel-Drive-Special" look haha. definitely get it dropped if you decide on em. not bad IMO
Joe
nismo066069 wrote:has any one have any information if it is possiable to put a 1991 nissan sr20det in a 93 honda civic any info please let me know it seems like a fun project but i was wondering if anybody have any suggestion on how to do it and what type linkages,brackets,hoses so if you have any info please help.
PUT THE FAST AND THE FURIOUS DVD DOWN
STEP AWAY FROM THE CRAPPY MOVIE
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
+1
Forget the SR, BOLT IN a b series and slap a t3/t4 turbo = fun car with thousands saved.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
You realize the transmissions are on different sides right?
Tulsa_S-13
Car: 1991 SR 240sx
Ha! You sir fail at life.
The Nissan Pulsar GTiR is IMO one of the most kickass Nissans ever built.
length - 3975mmwidth - 1690mmheight - 1410mmwheelbase - 2430mmcurb weight - 1220kg (2689.639 lbs)maximum speed - 223kph+accelleration 0-100kmph - 5.9 secondsaccelleration 0-400m - 13.9 secondsengine model - SR20DETengine type - turbocharged inline four, dohc, 16 valves, intercoolermax power output - 227hp @ 6400rpm (or 171.5 kw)max torque - approx. 290 nmcompression ratio - 8.3:1turbo - Garret TB2804 (T3/T25 combination)control system - electronic port injectiontransmission type - 5 spd manualsuspension - 4 wheel independent with front macpherson struts, rear parallel links4wd system - ATTESSA with viscous coupling centre diff and viscous LSDbrakes - vented front and rearABS - A4 sensor, 2 channel electronic anti-lock
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
