Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Jun 11, 2008 5:49 am
We have plenty of guides on re-timing the motor to factory specs
However, that's not the problem with a melted coil pack. I'm assuming they're melting at the top of the coil. Most likely, you have some crossed wires supplying constant voltage to the ground terminal on the coil pack (they're all on a shared ground) I would start looking at if the negative pin is seeing voltage with the coil unplugged and the car turned to "on"
After that, check to see how much current is being drawn across the positive terminal.
