vocationalzero »
https://forums.nicoclub.com/vocationalzero-u87315.html
Thu Jan 24, 2008 10:35 pm
I have been working on my swap for 4 months now and the problem is is that I can not seem to get the engine/transmission to come out. I am practically positive that I have disconnected everything. The harness is gone, heater hoses are gone, A/C is disconnected, no vacuum lines, and nothing I can see from any side. Now the problem is is that it won't come out. I go to pull and it moves about 1 inch and nothing more. I even disconnected the drive shaft at the differential. Also I can not disconnect the engine and transmission because the bolt at the top of the bell housing is almost stripped around so there is no drilling or sockets or anything that can get to it. The transmission dips down so that it all angles but when I tug on the hoist it barely moves. The exhaust is already removed and so is the transmission mount + cross member.But I noticed that there seems to be something holding on behind the intake manifold but I can not see anything still connected behind it. Because it seems to lean when I go to lift it up. And this is the only thing holding me back from getting it done.And I have been at this point for a month now. It is a 92 model and I have everything else pulled off.If there is anything else I need to add let me know.Any help is appreciated.
