Sr20 swap $5000 to spend What to get?
DriftS14
Other than the car and flywheel, I purcased and installed all I have in my sig for $5032 (shipped). Enjuku Racing.
BuudWeizErr
Remember though David, it was obvious what your motor was put through. There are certain indicators to look for to see what your motor was put through in Japan. Like what clutch is installed, the condition of the clip, mods, cam lobes, etc. Your clip had holes drilled in the dash for gauges, stickers on the valve cover, was an obvious sileighty conversion, little stuff like that. I don't know what clutch was in there or what your cam lobes looked like, but mine lacked all of the above and hasn't given me a single problem in almost a year of driving it.
EDIT: Not to mention the horrible wiring job the crazy japanese person did on their silvia headlights.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
yup, it definatly depends on the condition of your motor. With the stock clutch attached, a good stock turbo and clean cam lobes, im perfectly comfortable leaving the stock timeing chain in there.
Phax
Car: Control dynamics
As Buud pointed out, the condition my clip was in made it obvious that the person who drove it before me, drove it hard. Whichever one you end up with might be in better shape.
silver240
Car: 1990 240sx coupe with s13 reedtop sr20det
thankx again guys. i will most certainly do all i can to the motor before i place it into my car such as gaskets, rocker arm stoppers, water pump, gauges, and fuel pump.in less than a month i will be a very happy sr20 owner and driver. thankx again.
silver240
do you guys think the stock fan and radiator off a 89 240 will do for cooling at temperatures around 80 degrees at stock boost.
180fan
Car: 89 fastback
I think the stock one rad will run a bit hot, but should work fine granted all things stock. If you're going to run more boost, I'd run a better radiator. If you're interested, I've got the little pipe and ends so you can use a 240 radiator for the sr from HT if you're interested. Not asking for much. Make me an offer if you want em.
Phax
Shrouded or unshrouded?
I'm running at stock boost. For cooling, I ceramic coated the turbo manifold, turbo elbow, and downpipe. I am also using the stock SR radiator, fan and shroud. Even on super hot, sitting in traffic, southern California afternoons... I've never seen the temp needle waver.
silver240
thankx 180fan for the info i donst think i will need the piping though i an getting mine custom made by a friend. thankx anyways.phax- yes shrouded how muxh did it cost to ceramic coat eveything therethankx again
s13SRmadness
Car: sr20dets, ka bashing
get more money...
