BEST1TUNING.COM wrote:If its in the tune....the SAFC may or may or may not fix the problem. Did it ever run right?
Yeah, I would check you're ROM tune. What kind of smoke are you blowing?
It sounds like you're running way too rich. Or maybe your TPS has a dead spot? If you're hesitating before boost and then it goes away when you start boosting, it's most likely the tune that's the culprit.
Let your car idle for a minute or so, and then pull the plugs. Are they wet with fuel? If you're spark plug gap is too wide, you'll know cause the car will hesitate at high RPM especially when boosting.
