Vegascorbin wrote:In need of education. I have never heard the term "Blowout" in referance to spark plugs before. I understand what you mean (the air/fuel mixture moving through the cylinder blows out the spark before it can ignite the mixture.) I also understand that this can be caused by too large a plug gap or a weak spark caused by bad wires/coil etc.
What I don't understand is how to tell when you are suffering blowout as oposed to other problems.
Spark blowout is just one cause of a misfire. There are three main types of misfires. Pre detination, late detonation, and failed detonation. Late detonation is a whole other bag of issues, so we will concentrate on the other two.
Pre detonation, also known as knock, or auto ignition. Knock happens when the air fuel mixture is ignited by something other than spark, this ignition happens before the piston reaches TDC. The main causes of predet are, overheating, spark plug heat range too high, lean AFR, or mis adjusted timing. Knock is very hard on engines, it can cause bent rods, cracked pistons, holly pistons, rod bearing failure, and bent or burned ring lands. Knock is often heard as an audible knocking noise coming from the engine, accompanied by a sharp loss of power.
Failed detonation. When spark fails to ignite the air fuel mixture. This failed ignition is most often caused by issues with the ignition system itself, though an extreme rich condition can also cause failed or late detonation, it is usually accompanied by black exhaust smoke. What makes failed detonation so difficult to diagnose is the multitude of causes. The ignition system on the SR20DET is rather complex, there are quite a few things that can be the problem, and they will all have similar symptoms. Something like a failed coil pack will cause a dead cylinder which is easy, where as a partially failed coil pack, or a coil pack with a crack in it, or its boot will have the same symptoms as an over gapped spark plug or a loose spark plug to coil connection. All those issues cause the symptoms we are discussing, a semi random misfire, only noticed at mid to high RPM.
The reason the misfire only occurs at mid to high rpms is due to a few factors. When an over gapped spark plug is the issue, the increasing airflow or boost at higher revs blows the spark out before it can ignite an adequate flame front. If a failing coil is the issue, the higher rpms begin to put too much load on the coil itself, causing it to fall behind, either not firing enough, or not producing enough voltage for proper spark. If the coil pack or coil pack boot is cracked, as rpms increase, so does voltage, that voltage will always choose the path of least resistance. When the voltage reaches a certain point it may choose to jump though the cracks in the coil pack or its boot strait into the head itself.
As apposed to pre detonation, where a sharp loss of power is felt, a random misfire caused by failed detonation will feel more like a stutter, varying in strength, determined by the source of the problem. Another issue is the intermittence of the problem, some people will only notice the stutter when humidity is high, or when it is raining, others only when ambient air temp is high.
I would delve further into the subject but my A.D.D. is acting up, and I cant seem to translate thoughts into words properly, which means this post is probubly full of spelling and grammer errors. I hope this information was helpful.
