Well its not the ECU, and the old ignitor was tested on a running car so it is know to be bad as well. I have the FSM, the continuity testing rom ECU to coils gives proper reading. The power wires all have proper 12v power. the CAS gives proper voltage readings, all the injectors do. everything seems like it should be working yet no fuel, no spark. I've reached my BS limit, I'm buying 2 q45 ignitors and a whole new harness.
There is only one other thing I can think of that may be wrong.... the lower harness came attached on the SR transmission, one plug is missing... but since the guy pulled this engine "running" out of his car to send to me I figured it must not be used. Also, there is HUGE thick black wire that runs by the block off the lower harness that is twisted together but exposed. Can a problem on the lower harness prevent the SR from running??
my plan now is to just get a whole nother harness, 2 q45 ignitos just to be sure 1 of them will work (I've been screwed so many times since this ordeal started ... no Rb25 after 6 months..boned SRwiring and ignitor when it came, person keeps sending me busted ignitors, that I can no longer afford to buy straight up SR ignitors which i why the Q45 ones.)
1) A new wiring harness prewired and tested before being sent to me.2) q45 ignitor since I think this one that I waited 2 months for for the person to finally send me is broken3) Take my lower harness off my KA transmission and put it on this one.
How does that sound for a plan... the gayest pat is not ONE person has an SR where I live so I have no test car that is known to be working to test my ignitor and wiring on.
Nightmare on Nissan street
