SR wiring madness
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
No...when i did my sr s13 into my s14..it was fairly easy. I'm not sure about s13sr into s13. I remember reading it some where that you have to wire the fuse box and stuff.... You only use the harness that is connected to the ECU and that's it...pretty much 1 simple harness, fairly easy. Easier than the damn H22 into a civic.
I just found it. Check out http://www.srswap.com It's under the INSTALL FAQ and ELECTRICAL. Tell me if that will help Martin
94teggy
Yeah for S13->S13 all you have to do is re-arrange a few wires around the fuse box by the battery, lengthen a few in the engine, and lengthen and change around the wires to the gauge cluster and the plug to the ECU stays the same.
-Jon-
Fibercus
94teggy wrote:For you the best thing I can recommend is to keep an eye on this site... http://sr20store.com/wiring.htm . He did a S24 into a S13( i know that's not what you're asking) but he's working on wiring diagrams so he may put up a S14->S14.
Good Luck man,-Jon-
Thanks for looking out, will do
94teggy
No Prob. If you get a chance Heavy Throttle or any of the engine sellers/swappers should be able to point you in the right direction.
-Jon-
