stock motor and turbofront mount walbro fuel pumpstock mafsrunning boost pressure silanoid so i assume im running 11 poundsthe idle is smooth so im guessing no boost leaksim gonna check for codes later todayFlatBlackIan wrote:We will need more info to diagnose.
What is done to the engine, internals, manifolds, turbo?
What fuel pump are you running, and how much fuel pressure.
What intercooler setup do you use, are there any leaks?
What MAFS do you have?
Are there any ECU codes?
How much boost are you making?
Start with that.
I take it you are not running a boost gauge? I would temp delete the boost solenoid, and revert to waste gate spring pressure. It is possible that you are getting fuel cut due to over boosting.757coupe wrote:
im running NGK Iridiums heat 6 i thought they were pre-gaped but i know i shouldnt always rely on that, what would be the correct gappingFlatBlackIan wrote:
What spark plugs are you running? You may be getting spark blow out.
What are the plugs gapped to?
Have you checked your coil packs for cracking?
For your boost level .028 - .030 should work fine. The preset gap is not correct.757coupe wrote:
ill check coil packs and delete the solenoid
