answer the man and we can help more.duffman1278 wrote:Whats your vacuum at? BOV not reciculated?? If you can adjust the spring on the BOV, try making it tighter
the only vacuum line that is connected is the one the T's off for the wastegate and the BOV, it's not reciculated, how do i crank the BOV it's a greddy RSduffman1278 wrote:Whats your vacuum at? BOV not reciculated?? If you can adjust the spring on the BOV, try making it tighter
Re-circulating will be cheaper and better course IMHO.srpowered240sx wrote:the set screw on the top of the valve. read up on the instructions or their website, but basically tighten it to keep the bov spring a little tighter, lets out less air, less stalling. you should look into recirculating, or getting a safc to control the decel air.
yeah cheaper, but not necessarily better.homeslicej2 wrote: Re-circulating will be cheaper and better course IMHO.
Yeah there was notinh wrong with the temp sensor it was just so damn cold outside and the front mount kept it right at cole on the temp gauge, is there another way to fix it besides recirculating???SideWays=smiles wrote:Recirc your bov to fix the stalling. Replace your coolant temp sender to fix the temp gauge.
yeah it sucks I'm gonna try to get one out from the ppl i got the motor from. I bet there gonna jerk me around though. Do you know any one with a t28 for sale??White Comet wrote:^ man sounds like u cant win
You have an SSQV don't you?White Comet wrote:some how i have no idle problems and i havent recirculated it at all
my temp sensor doesnt show anything either. i think its way too cold outside. or maybe its a bad sensor. my bros s13 sr reads normal.95s-14 wrote:
