You don't need a different coil. I have 640CC injectors and NO problems with burning fuel with my stock coil. I know people on these boards have said it many, many times.beatd wrote:After i hardwire the coil how big of a sparkplug gap could i run for a bigger spark?
If your injectors are flooding on 'initial injector pulse sequence', that means your tuner didn't configure something right.
My motor turns over after cranking for like 2 seconds.
When you check your car first thing in the morning are the plugs wet? Maybe you have a leaky injector.
