SR t25 internal wastegate question
psi240
Car: 1997 240sx
i know that the wastegate is set at 7psi .. Is there any way to modify it to set it at 5 psi ? or is there any aftermarket actuator i can buy thats adjustable and can be set to 5 psi
thanks
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
HKS makes an adjustable actuator but I don't know if it'll go that low. You'll probably have to get an electronic boost controller
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
You cannot drop boost below factory level, even with an electronic boost controller. Why do you want to run 5 psi anyways, you would hardly adding any power. The only way to do it, would be to find an actuator from a different application that opens at 5 PSI, you would have to modify it to fit the T25 of coarse but it is possible, just not worth it.
psi240
Car: 1997 240sx
SideWays=smiles wrote:You cannot drop boost below factory level, even with an electronic boost controller. Why do you want to run 5 psi anyways, you would hardly adding any power. The only way to do it, would be to find an actuator from a different application that opens at 5 PSI, you would have to modify it to fit the T25 of coarse but it is possible, just not worth it.
its for a Ka-t and 5psi is plenty for winter. has anyone done the modification before?
Tulsa_S-13
Car: 1991 SR 240sx
Come on man, think realistically. It's only a 2psi difference. Which shouldn't be a problem since I know you'll be running something other than a stock fuel management system. Or at least you should be
IanS
What does winter have to do with it, I run 11 PSI and they dont plow the roads around here for like a week after it snows. You have a T 25, once the tires start spinning the turbo cant keep up, it stops making boost, and believe me, you can spin the tires in the snow with 5 psi just as easily as with 7 psi.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
If you are trying to get more traction in the winter get better tires and an AWD or FF car. The 240 is never going to have excellent traction in the winter and low boost isn't going to change that.
psi240
Car: 1997 240sx
winters are a bit harsh in canada.. and the t25 makes boost as soon as you step on the gas in a Ka .. and keeps making boost up into the higher rpms. Winters are only 1 reason .. the other is that i want to run lower boost to make Ka#2 last longer.
Getting back to the topic ... has anyone here modified the T25 wastegate to 5psi or less?
Z28ricer
Car: Cars
http://www.atpturbo.com/Mercha...e=WGT
Theres a 6 psi actuator, guess that would get you a little closer to your goal, that or buy a used SR actuator from someone thats worn out and doesnt boost a lot. The other option would be to go to an external gate, i think tial has a spring for the 38mm gate around 4.8 psi.
redtop91
Or you can try to modify the boost restrictor in one of the stock boost solenoid's lines.
IanS
psi240 wrote:i want to run lower boost to make Ka#2 last longer.
If dropping from 7 PSI to 5 psi is the difference between a blown motor and a not blown motor, you probably shouldn't have a turbo on there to begin with. No I am not talking **** about KA-Ts, it is a general statement.
psi240 wrote:Getting back to the topic ... has anyone here modified the T25 wastegate to 5psi or less?
No, you need a new actuator, one that is set for 5 psi.
redtop91 wrote:Or you can try to modify the boost restrictor in one of the stock boost solenoid's lines.
The restrictor cannot lower the boost past the actuator set limit.
psi240
Car: 1997 240sx
the 5psi wastegate idea im contemplating is as a precaution, until i can afford ems.thanks for ur input though
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
get a differnt car for winter liek me.
psi240
Car: 1997 240sx
idahotuner wrote:get a differnt car for winter liek me.
i have 3 240's ( one is just for parts ) .. i prefer to drive the Ka-t around rather than the Auto n/a ka
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
good call. now jsut weigh the cost vs benifits
homeslicej2
SideWays=smiles wrote:You cannot drop boost below factory level, even with an electronic boost controller....
oh yeah I are we todd it
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
lol ok that post made no sense
