sr swap driveshaft
chuckd502113
can i use a manual ka driveshaft or do i need a sr because my 240 is auto and befor i get a driveshaft i just want to know if if i can use the ka one thanks
Justin35ll
Car: s13 coupe sr20det
the ka driveshaft will bolt right up, but you need a five speed one, auto won't work
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Justin35ll wrote:the ka driveshaft will bolt right up, but you need a five speed one, auto won't work
Also if your car has ABS you need an ABS shaft, if not, then a base shaft.
