sr starts and dies
luis741953
Car: 1995 nissan 240sx se
hey here is my problem, my car will start but will not stay on, it will just die 1 second after it starts,i try to give it gas but nothing happens like somethingis telling my POWER FC not to activate my fuel injectors i've checked maf got 12 volts on power lead, replaced fuel filter checked fuel pump, fuel has pressure after the fuel filter, could it be a clog in the fuel line after the fuel filter?? please direct me in the right direction, also does the power fc give you engine codes?? ( when i go to sensor check in my pfc AF is lit im not sure if this is normal, when i start the motor FP and VTC light up...any help is appreciated
s14 sr20greddy fmicfull exhausrsuper intakeavc rpower fcwalbro fuelpump
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
check for injector pulse during cranking, check for spark during cranking.
