Kalypso123 wrote:Ian what thermostat do you recommend
Thermostats are very simple, some people will suggest dealer parts, but in reality often times the OEM parts are just repackaged Stant or Wahler items. Others will say that a Nismo, TRD, or Mugen performance thermostat is the only way to go, but again this is not true. It is true that these are performance thermostats, but their only difference is the opening temp. Some will tell you that the lower opening temp will keep the engine cooler, when the truth is, most ECUs control engine temp using electric fans. This becomes troublesome on engines like the SR which do not have ECU controlled fans, the thermostat then controls engine temp.
People need to look past the misinformation. If you engine cant keep itself cool with a thermostat that opens at 185 degrees, how is having a thermostat open earlier going to change anything? If you have overheating problems a lower temp t-stat most likely wont help, unless your current t-stat is stuck closed, in this case, any working t-stat will fix the problem.
Is running cooler really better? Modern ECUs are designed to run in a certain temp range, running richer when either too hot or too cold so as to prevent detonation. If you lower your running temp, you are running the risk of dropping out of the specified operating temperature range, which can decrease mileage, increase carbon buildup, as well as shorten catalytic converter and oxygen sensor life.
The final answer? Get a quality thermostat with an opening temperature the same as marked in the FSM. Leave the performance t-stats for race cars, or engines with full engine management.
