IanS »
https://forums.nicoclub.com/ians-u23642.html
Thu May 24, 2007 7:27 pm
yes, sounds like a boost or spark issue, make sure the plugs are correct and have the correct gap, check your timing, make sure you unplug the TPS while checking timing, and also make sure your coil packs are tightened down all the way. Also check for boost leaks.
