devil_child »
https://forums.nicoclub.com/devil-child-u58421.html
Mon Nov 26, 2007 9:09 pm
fyi you'll still spew lots of black **** with an n60. there is no way the afl maps on the n60 and whatever ka24de maf are exactly the same. doesnt work all that well, just get an safc with knobs for like 60 to 70 if on a budget. Injectors will not provide any power increase whatsoever also. I've been there btw.
needed sr smic and piping, a bov other than stock cuz they all leak, sr dp sr elbow pipe, t-2 series manifold, -3 an oil line at least 4 feet, oil restrictor, oil sandwich plate, oil drain line and fitting for tapping the oil pan, some sort of primitive tuning safc knobs, a wideband, knock timing back half a degree for every lb of boost, oh and a boost gauge.
if you really need injectors, go rip some out of an altima at a junkyard.
and 270s don max at 7lbs the amount of boost is realtive. in theory they max at around 215hp to 217hp so safeish at 200hp. same goes for 370s around 295 so say 280hp.
