So your Ka was a sohc and you were able to use it on the sr?elvis240sx wrote:i swapped my ka throttle body onto the sr20 engine. then i just bypassed the coolant from running through the throttle body with a short piece of pipe. for a mount for the throttle and cruice cable i used the ka bracket. you can bore out the counting holes and trim the back edges to rotate it perfectly into place. a dremel works great here. now for the wiring. i have a s13 sr into a sohc s13. what i had to do was jump the speed signal from the wiring going into the ecu to the wiring for the cruise control unit. luckily, the cruice control module sits right behind the ecu in the passenger floorboard. so all you need is a 6 inch peice of wire and some connectors. remember, you want to get the speed signal from the ecu to the cruise module but not cut it off from the ecu. get some three way connectors.
