Spraying the center light trim
92Q45guy
Car: 92 Q45 93,000 miles / chain guides / transmission cooler / synthetic fluids / lots of love!
Just finished up on the body work today. Painted rear bumper from clearcoat peeling, door trims, bottom of front bumper, and I painted the center trim were the reverse lights are. This is how I did it....mask off were reverse lights are. I used a ruller to make the cut's perfectly straight. Ruff up the ugly trim with 320 or 400 grit.... I used 400. Be carful not to damage the tape! Use a tack rag to clean up the ugly trim. Spray on the primer. I use a 2K urethane. Spray 2-3 coats of the primer. Allow to dry 1-3 hours. Then, Wet sand with 800 grit. clean it up with soap and water. Spray the basecoat allowing 25-30 minutes between coats. When the basecoat is still a little wet carefully peel the tape. Spray 2-3 coats of clear. wetsand again with 1500-2000 then buff. You might not even have to wetsand. It's all about how good you are at spraying, how fine tuned your gun is, etc.. Enjoy!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Looks clean. I like it. I think I'd like the Infiniti logo in the middle of it. I photoshopped it to see how it would look and also with and without trunk lock:
You can see more pics in this thread:zerothread/243884
My favorite is still this one:
Yours is very close Thanks for sharing.
92Q45guy
It does look nice with the logo in the middle. I like the red piece connecting the two tails together.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Proof positive that Infiniti did it right the first time.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
i want a Junction Produce kit like that. I want my Black 92 to look just like that.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I think i would have liked it better painted black.
lino
Haitian_King wrote:i want a Junction Produce kit like that. I want my Black 92 to look just like that.
Go to this link:http://www.junction-produce.co....html
Go to the left side and click on:インフィニティQ45└INFINITI Q45 「前/後期」
Haitian_King
thanks. I can't read the stuff though. It's all rectangles and such. I don't want to look at the wrong parts. What can I do to get the text to appear properly?
lino
Use the following site for translating:http://www.babelfish.altavista.com/
Use the following site for currency exchange:http://www.xe.com/ucc/
Haitian_King
Thanks.
The 8 point kit for my Q is going to run me $5520 and i don't think that includes shipping.
Plus I have to get it put on and painted. F Word.
How hard is it to install a Junction Produce Aero Kit myself? Would it include cutting, molding, and sanding? Is it bolt on? Please say yes!
