DerrtyByrd wrote:Thanks... Now i know this is a Nissan/Infiniti forum... But how are the Scion's acheiving this? They are FWD... so are they running upgraded suspension to strengthen the hardware? And do we have it available for the B15? Once again i know this is a Nissan forum but do anyone have the answer?
They are just dealing with the increased failure rate. Most of these kids these days (read Scion owners) wont own their car long enough for it to matter, they do it just for looks without understanding the consequences. I would bet most of them are not daily driven, and they have so few miles that for most of them, its not yet a problem. Also, the XA/XB are under powered, and they produce almost no torque, while your QR25 is rather torque, you will have a harder time putting that extra torque down.
You could get some heim joint tie rods, with beefy inners, as they would take the abuse better. As for ball joints, Im not sure whats available for the B15s, but Im sure a Moog part will deal with quite a beating. As for the wheels bearings, you will just have to put up with replacing them on a regular basis, which, depending on your driving habits, may be as often as every 10K miles or so.
I would also suggest getting some decent coilovers, without them, you will be cutting up your tires on the fenders any time you hit a bump. You could risk blowing tires, or even denting your fenders.
Another thing to keep in mind, you will need to remove your inner fender liner, as the extended turn will most likely cause rubbing on hard turns.
