Sportmax 006
elpiar
Car: 1992 KA-T
finalgear wrote:did you get them ?
yeap fits perfectly with my setup. i'll take pics sometime.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Yep they fit perfect in 17x8 +35 17x9 +35, I don't remember if I tried them out before coilovers, but I think I did- and they fit fine
S133P3R
Car: 1989 S13 240sx
hey 1sikS13,I was just reading your post about "sportmax 006 wheels" and i have the 006 in 17x8 and 17x9 for the rear. are your wheel offsets +35, as seems to be common? and what size tires are you using? any info would be much appreciated!
ka-t in progress
Car: 1990 240sx coupe
im having this problem to. i have 18x8.5 +35 offset up front and they will not clear my coils. i would need a 20mm spacer but i can't use a 20mm spacer with studs because my wheels don't have the slots for the spacer. i could put the spacer on but my wheels don't have slots in the back for the wheels to sit flush on the spacer, its just flat and the nuts wouldn't sit. so im very frustrated
sil80drifter
Car: 1990 240SX Hatch
I only needed 10mm spacers on my s13, and they didn't have the bolts to secure them to the hub, only extended forged studs, so they fit fine.
sil80
ka-t in progress
u have +15 offset right? if u could direct me in the right direction to fitting i would appreciate it. i need at least 20mm up front. im debating on selling and getting an s14. which spacers do u have? if i don't have to bolt them onto my hub i may be ok
sil80drifter
no its +35, i originally thought it was +15 but its not. there are a few people here who run this size and it works with a 10mm spacer. thats all you need
sil80
ka-t in progress
im guessing that u run coilovers right? which ones do you have?
sil80drifter
I used JIG Magic and TEIN HA equivalent. Most coilovers are the same in terms of wheel fitment, they are about the same size as others.
sil80
nam3less
Car: 1990 240sx
Alright... after I read the whole thread... this is what I got:
My desired Setup:
Megan Coils All Around
18x8.5 215/4018x9.5 225/40
From what I read I'll need a 5mm (OEM brakes all around) for the front and none for the rear (assumption based on sil80's set up... so 5 will be okay cause you have Z brakes right sil?)
I am actually still debating whether to run the same tire set up as your sil80... the stretch isn't that bad... the 10mm sits flush all around? in 2nd thoughts... didn't you sell your set up? lol
nam3less
Car: 1990 240sx
finalgear wrote:here are the pics plus new crib Rear Front
Modified by finalgear at 5:50 PM 2/25/2008
sits nicely... very nice and no spacers you said right? does .5 inch do that much?!?!
sil80drifter
Yeah 5mm should be fine as you can see from the pix. The front rubbed the wheel weight (from balancing) on the coilover, but 5mm outwards should be fine. They may stick out a bit on the outside, but nothing that can't be fixed with some cambering and/or rolling the fender.
sil80
finalgear
Car: 91 240sx /90 240sx
well here is the setup coils clear fine in the front and rear no spacer needed and wheels clear 300zx brakes just fine with no spacer will have new pics up tomorrow
finalgear
well new update i tried a 25mm spacer in the rear now making it +10 all i have to say is baller and you will have to roll you rear and have a stretch on your tires a pull is not required unless you adjust your rear camber i will have pics up soon iam also checking how the 25 will look on the front.
Modified by finalgear at 4:21 PM 9/14/2008
nam3less
Car: 1990 240sx
Awesome, since I'll be installing these in the parking lot where I'm buying them (lol) I'll need to be prepared. I'll pick up 5mm spacers for the front and raise the car up a bit until I can get a nice roll/pull.
Did some picture searching too for the 215/40 for the 8.5 and 225/40 on the 9.5 and it isn't a crazy stretch... I think I'll go with that set up. Thanks for the input
finalgear
teaser pic with 25mm spacer on rear
nam3less
Car: 1990 240sx
oOOo that looks nice..
more pics!!!
and do you have adjustable camber arms in the back?
finalgear
when i get the spacers for the front i will take better pics
240Kid4
Car: 1992 240SX Super Hicas
Damn that is nice. Are they 18x9.5 in the rear?
finalgear
no 17x9 +35 in the rear with 25mm spacer so +10 and 17x8 +35 with a 5mm spacer so +30 i need a 10 or 20 in the front i think
240Kid4
Really? How come the lip looks so big? I have 17x9 all around and it doesnt look like that idk maybe it is the angle but it looks good.
finalgear
yea its the angle
240lookis
Car: 1990 240sx hatch
are you sure that's your car? i saw that exact picture on zilvia in the fitment thread and it was this car
finalgear
i played around with the first pic in ps here are some better pics i had to lift the back of the car a little because i was rubbing on bumps
nam3less
Car: 1990 240sx
that looks sexy...
I asked u earlier.. didnt know if u replied... but do u have camber adjustables in the rear? or us lowering ur car that low just making that angle?
**edit** what did you use to roll?
Kalypso
my god this thread has more then 13,000 views
wtf
finalgear
nam3less wrote:that looks sexy...
no camber adjustment in the rear just lowered and i used a wood baseball bat lol to roll the fenders
sil80drifter
cuz 006s are TeH SEX!
nam3less
Car: 1990 240sx
geeez... dont know where/how u guys got urs mounted on.. but for some reason... pep boys couldn't even get the tire around the wheel... and firestone couldnt do the 225/40 for the 9.5 >.<
Well... firestone said they were gonna try another place.... pics tomorrow....
nam3less
Car: 1990 240sx
Well, the wheels are on... they look pretty good. I can lower it somemore, but didn't have a bat to roll =/ Here is a teaser pic! Will post more when the car/wheels are clean and the car is slammed hehe...
