i see that his maf is in line with the cold pipe. does it run ok like that or does it have to be before the turbo???spooled240 wrote:
Modified by spooled240 at 1:44 AM 4/14/2008
G2 gold caliper paint. It's a 2-part paint you can get on ebay that you paint on with a brush. The coats are thick and look pretty protective.okinawa drift wrote:what brand paint did you use on the wheels?
When was this? I don't remember free-reving it at idle in the parking lot, not the greatest thing for your engine anyways...I did however take a few buddies for a ride on the STREET right off the parking lot if that's what you're talking aboutkrisdeezy wrote:oh i remember you..you were at the 240 meet in arcadia and kept reving it ...anyways nice car very clean..
The blow-through mafs setup as it's called just worked for me because I wanted to have an open atmospheric bov with my tuned ecu. I did the suck-through setup but it stalled on me a few times because the bov was in-line between the mafs and the throttle body releasing metered air into the atmosphere. With my current setup, the bov is BEFORE the mafs so the expelled air isn't metered, just fresh pressurized air from the turbo.white90esex wrote:Hey, I just realized you had the maf after the turbo. Ive never really read/herd much about these kinds a setups. Do you have to do anything special to make it work out like that or does it work fine? Also is it ok to have those mafs take on pressure?
just curious
ahhh i'm just ragg'n on yaspooled240 wrote:
I know duralast aren't the tyte race-spec pads but this is my DD and frankly they will do just fine. They can always be switched out later anyways..
you should take out that fan and its shroud and replace with an electric fan!!zirgo FTMFW! plus doing so will give power back to the crank seeing as the fan is attached there so e-fan=more hp&tq also =FTMFWand it will free up room and clean up that engine bayjust my 2 centsspooled240 wrote:
spooled240 wrote:the green roadster is my dad's triumph tr-4a with IRS. Very nice, he has a red one too, but I don't think it's in the pic.
i dont wanna bite your style, but i like that color for the same reason, would it bother you if i painted my teardrops that color?spooled240 wrote:just some regular old dupicolor-I didn't get any wheel coating paint since I've had pretty good luck with regular old rattle can paint on wheels before. Also, it is a bit harder to find weird and cool color choices in the wheel coating (selection is usually limited to "black" "silver" and "bronze", a little boring IMO)
the color is actually called "arizona beige" believe it or not, bronze was a little too played out and dark for my taste.
Thanx for all the comments so far really appreciate itscheffler wrote:hey that is a nice clean setup.
Quick question the slots on your rotors.. is that the right direction cause i have mine going the other way? I dont realy know if there is a correct way or if it maters.
If you or someone can clear this up for that would be great.
