SPL subframe bushings on an S14
Nismo_Freak
Car: 89 Nissan 240SX
veilside180sx wrote:I'm desperately feelin' the need for new sways though now, and Tie rods
I do not suggest aftermarket sways for someone that is planning to go coilovers later.
The spacers shouldn't make any clunking noises, please double check them.
veilside180sx
i already have coilovers alan...they mellowed out now(spacers), so no more clunking. I have 7/5 D2's
Nismo_Freak
veilside180sx wrote:i already have coilovers alan...they mellowed out now(spacers), so no more clunking. I have 7/5 D2's
Unless you are building a drift car I don't suggest getting sway bars. Better tires would be a better option, or if you've completed your suspension I'd move towards chassis stiffening.
If you are getting alot of roll you need to add preload to the spring, this will raise the spring's rate and reduce the roll. You can also get lower control arms and tune out some of the roll couple.
veilside180sx
i'll pick up some STB's and see if that helps at all.
Nismo_Freak
We carry the Okuyama Carbing strut bars, they are the best looking and one of the best performing strut bars on the market. Made of light aluminum and in a single piece design, the welds are beautiful as well.
Front - $228Rear - $281
Lead time on them is 4-6 weeks. Price is a shipped price.
For more info send us an email: [email protected]
veilside180sx
those are beautiful, but i think a little ritzy for me. I'll probably just wind up with ebay specials. The next thing i'm doing is to weld on reinforcements on my tension rod bracket(ala Power Brace). Hopefully that will give a little front end rigity as well.I am ordering HE's too. To switch for my D2's.
Nismo_Freak
veilside180sx wrote:those are beautiful, but i think a little ritzy for me. I'll probably just wind up with ebay specials. The next thing i'm doing is to weld on reinforcements on my tension rod bracket(ala Power Brace). Hopefully that will give a little front end rigity as well.I am ordering HE's too. To switch for my D2's.
Cool, just thought I'd show you what we got :)
chmercer
i picked one of the carbing bars up for a z32 at the shop and was like WTF. they weigh like nothing, welds are clean and piece is very strong.
veilside180sx
so help me understand how this lca works, instead of sways. Since i saw that Koguchi is just running aftermarket lca, instead of sways. Explain to me how that does it. The most that i can get out of it is that as you extend the lca is transfers some of the spring compression at a diagonal putting the additional side forces on it. That's the most sense i can make of looking at the design. Enlighten me please
Nismo_Freak
veilside180sx wrote:so help me understand how this lca works, instead of sways. Since i saw that Koguchi is just running aftermarket lca, instead of sways. Explain to me how that does it. The most that i can get out of it is that as you extend the lca is transfers some of the spring compression at a diagonal putting the additional side forces on it. That's the most sense i can make of looking at the design. Enlighten me please
Basically you can raise and lower the control arm in relation to the spindle. This either reduces roll couple (moving arm up), or increases it (moving arm down). With enough increase you can cause excessive body roll and get the car to skid.
veilside180sx
i just did some more reading, everything is making more sense. I think when i get the HE's i'll leave them the heigth that Tein sets them at.
Although my car does look sweet being low.=)
