SPL Parts Question
VinceSez
Car: 1992 Nissan 240sx
MIKE JONES!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Juujai wrote:thread jack...
how is splparts.com anyway right now
they're in austin texas i believe and hurricane rita is about to hit houston which is not too far from austin...??
it's been a while since i made the austin to houstin run, but i remember it being a long haul. like a 5 hour drive.
Anand
Car: 95 Nissan 240SX
Loveless wrote:
what does that suppose to mean?
are you saying that this is hollow and so so good as these?
didn't someone on this forum asid cutting/burning the old bushing off resulted in rusting in the long run?
that's not what I meant.. but yea, the first ones are good but the second ones you posted are more solid since it replaces the rubber bushings completely.
it is far more difficult to put those in though, I got the first ones and it was cake and work perfect.
grimple1
Car: 95 240sx Zenki
They say to freeze the solid bushings for about an hour and they'll fit right in the hole.... since metal contracts when it's cold and expands when hot.
naed240sx
Car: .....
grimple1 wrote:They say to freeze the solid bushings for about an hour and they'll fit right in the hole.... since metal contracts when it's cold and expands when hot.
Its far more complicated than that. you have to remove the whole subframe, and torch, cut, saw for hours to get the old bushings out before you can wack the new ones in. There is a writeup on here somewhere.
Fenvy
Car: 2005 350Z Base 6MT
got it installed along with nismo power brace today
driving impression: seems to be stiffer in the front, the car seems more stablized in the front but without an alignment, I don't intend to push the car
