Thanks. I used this tool to pull the fasteners without breaking them in the Accord. Hopefully they are similarly shaped. My front brackets probably won't get here till Monday, so I'm just doing the 6x9's today.generic808 wrote:The door panels are held in place by a bunch of snap fasteners. I believe there was about 6 on the bottom portion of the door. Start by pulling down and outward and they'll pop out. Along the sides there are a bunch more snaps. And the hardest part is behind the armrest; there's these really irritating fasteners that have to be worked and wedged every which way to remove. After removing the fasteners, pull door up and outward. You don't have to totally remove the entire panel, just pull out enough so you have room to work with.
I could've told you that! When you told me you got the adapter, I thought they finally made one for the Altima's, but I guess not. They sent me that stupid Scoche brand xB adapter which won't fit. Isn't it painful drilling into a new car?ssjones wrote: Don't bother with the Crutchfield front speaker rings. They just send you Scion XB rings which require drilling anway.
What speakers are you running? I wanted to keep the factory look, so I didn't change out my head-unit. I initially installed Polk db series speakers all the way around, but the volume level was too low because they were 4ohm load speakers, as opposed to the factory Blaupunkt's which are a 2ohm load. I returned them to Crutchfield for the Reference Infinity's because they were 2ohmers.
BTW, thanks for the pics. I'm sure it'll help some people out.
Crap, we'll heading out now, I'll either love or hate them.generic808 wrote:Yup, standard sound system.
The cuts on my hands should be healed by the time the Infinity's arrive from CA!generic808 wrote:Both the Kappa and newer model Reference speakers are 2ohm loads. Crutchfield carries both, well at least 6 months ago they did. Sorry to hear about the situation. You'll like the Infinity's much better than the Kenwood.
SSjones, I have a question, for one of my projects I will need to pull out the cubby.. could you explain how to do this... does it just pop out, snap out, are there any hidden srews? I just don't want to break it.... thanks!ssjones wrote:Sure, I'll snap some pix. Any surprises pulling off the door panels? It looks like there are screws behind the chrome door pull, under the plastic cover and in the armrest. I have the door panel tool to pull the other fasteners.
Here's a shot of my XM install. I made it exactly 60 miles without my XM. Came home and popped this in. In m Accord, the unit fit into the cubby, neatly hidden. On the Altima, it also fits but the door completely obstructs the display. I decided to mount it with mounting tape to the front of the door. I can still lift the door up with the unit in place.
The cubby was surprisingly easy to remove, but the shifter plate doesn't give you much wiggle room. If I could have removed the shift knob, that would have made for easy access. I drilled a hole in the side of the cubby to run the antenna. The 12V plug in the back makes power a snap. I run the FM modulator, which has served me fine. I called MyRadioStore.com today but confirmed there is no AUX cable that works with the '07 and up Altima. This will do for now.
