Spark plug questions
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
OK, I know spark plugs have been covered a few times and I was searching around and basically found this.
- heat range 6 for less than 12 psi on stock turbo- Gap is between .028 and .036 ( i have seen alot of different answers)- NGK irradiums or coppers are best
so. I guess the question is.
Say im running a larger turbo but low boost until a good tune.
What would be the best plug for my application and what gap sould it be. Then once I have the tunability what should I bump the gap up to?
Im wanting to get a plug that will work now but will be able to work good under more boost laters too.
Im thinking maby the BKR7EIX ?
Thanks for your input.
GoTRicEo0
Car: Slowest crap the earth have ever seen.
Bumpy. I would like to know about this also.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
The BKR7EIX with a .032 gap will suit you perfectly, once you turn the boost up, drop the gap down to .028 and you will be set.
codyace
Car: S14 w/redtop
Anything over 12/13 pounds gets a .022 -.024 gap from me.
No issues, same mpg, less worry.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
sweet, thanks. Thats a pretty straight forward answer.
1992hatch
Car: 91 coupe 5spd
i went with a cooler plug should i still gap it the same?
