IanS »
https://forums.nicoclub.com/ians-u23642.html
Sat Jan 26, 2008 5:23 pm
Im not sure I can give you a good answer as to what plug you should use, but I can give you info to help make that decision for your self.
How spark plugs work
Heat ranges, the heat range of the plug determines how much head the plug itself will dissipate to the head. For example, a hot plug will not dissipate much heat to the head, which means it will stay hotter when the engine is running, this is good because the hot plug helps burn off excess fuel and keep the plugs from being fouled. Hot plugs will not foul easily, but because they run hotter, they are more likely to cause pre-detonation which can destroy your engine. A colder plug on the other hand will dissipate more heat to the head, therefore running colder, which makes them more susceptible to fouling, but the are less likely to cause pre-detonation.
Electrode types, the three most popular electrode types are as follows, copper, platinum, and iridium. Copper is by far the best at producing spark, it will create a more powerful spark than either platinum or iridium, but the down side is, copper is soft, it burns away as the plug fires, and it will have the shortest life span of the main three. Platinum is a often used because it is much harder, therefor it lasts much longer, permitting longer service intervals, its only downfall is you wont get as powerful of a spark. Iridium is relatively new in the automotive market, it is much harder than platinum and conducts much better as well.
Gap is also very important, a large gap makes the electrical jump harder, effectively increasing voltage, this makes for a more effective burn. With a large gap you get good burn, but you run the risk of blowing the spark out at high rpm. A tighter gap wont blow out as easily, but will not burn as hot either.
Its been a long time since Ive dealt with the KA, so I don't know appropriate heat ranges or gaps, but I can tell you what you should look for. You should run a heat range slightly colder than stock because you do not use the car below running temp, and you are running at high RPM for extended periods. As far as gap goes, you can rely on those on this forum to get close, but you will need to find the right gap for your car using trial and error, you want the gap as wide as possible without spark blowout, this will mean lots of test driving, and re gapping. Plug type is up to you, if you choose to run copper, bring lots of spares, I would recommend changing them very often, they will wear quickly under that abuse. I would stay away from platinum, its just not what you need. If you choose to run iridium, you wont need as many spares, but at least one set is a good idea, I don't think iridium is worth the extra cost in your case, the juice isn't worth the squeeze per say.
If you have any more questions, just ask, I hope this was at least slightly helpful.
