spark plug heat question
Team_Undisputed
Car: 90 240SX (Piggy)
ok so im getting ready to order some spark plugs for my red top and ive been getting some mixed messages from all the stores that carry them. ive been looking in getting the heat range 7 spark plugs because thats what the nissan guru in town recomended but i just went to enjuku racing and they said that the 7 heat range is for cars that are running 13-15 psi . i have a red top SR20 wiht a greddy front mount, KOYO rad, full exhaust and im running stock 7 pounds now my question is should i go with the 7 heat range plug?? i have the 6 heat range plug right now but i looked at it today and it had a yellow brownish tint just where the hexnut meets the ceramic which usually means to get a colder plug right?
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Sounds like the plugs you have are perfect. The color you are describing is good. Gap them to .032" and you will be fine.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
if you are only running stock boost run BKR6E ngk's BKR7E's are a hotter plug for higher boost so the spark doesn't get blown out by the higher compression Enjuku is absolutely right
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
240life wrote:if you are only running stock boost run BKR6E ngk's BKR7E's are a hotter plug for higher boost so the spark doesn't get blown out by the higher compression Enjuku is absolutely right
You have that backwards, the 7s are a colder plug. They dissipate heat to the head more efficiently so as to not pre detonate at higher cylinder pressures.
Team_Undisputed wrote:i have the 6 heat range plug right now but i looked at it today and it had a yellow brownish tint just where the hexnut meets the ceramic which usually means to get a colder plug right?
You are correct, I would suggest the 7s. I have been very pleased with my 7s for all boost ranges from 7 to 13 psi. I had issues with the 6s above 10 psi
Project240
7s are good for most SRs. 6s are fine if you run a 100% stock SR, but who does that? =P
