something is wrong with my clutch!
AlfredoS13
Car: 1991 240sx hatch w/ SR20DET red top
today I was driving home from work, when I left work the clutch was fine, I went over a bump on the road and I heard a noise in the back of the car. I didn't think much of it since I have some coilovers in the trunk, was coming up to a red light so I went to down shift the car and when I press on the clutch pedal it was super soft, the pedal is all the way down, about 2-3 inches from the floor. The car still runs and shift fine, but its hard to get it into first and reverse and when I do its a pretty rough engagement.
Any ideas, what could be woring with it. The car still runs strong.
vutony
then bleed ur clutch
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
yes check your clutch lines and slave sylinder, then bleed the system
AlfredoS13
the clutch was fine for months. what happen to me make it that wait. That's whats puzzling me.
S13FASTBACKSR
Car: '92 Fastback SR powered
AlfredoS13 wrote:what happen to me make it that wait.
AlfredoS13 wrote:That's whats puzzling me.
Thats whats puzzling me too...i think im gonna stop coming on this forum and trying to help lol..its too hard to figure out what some of you guys are trying to say
IanS
it must have somthing to do with Easter, its like attack of the bad spellers
PS who ever turned on the spell check thing
I heart you
corey240
Car: 1993 Nissan 240SX Base Drift Machine
sounds like my clutch befor, a few times i would get up to a light and stop. and randomly at times the car wouldnt go in first gear. i was lucky my friend was in the car and he helped me push that thing in gear. the transmission and gears are fine. it only did that like 3 times ever and it didnt do it for a whil.
btw, how do you put transmission fluid in an sr? iv never had to do it so i dont know how.
90SRpwrd240
Car: 1990 240sx SR20DET
This happened to me 2 weekends ago out of nowhere also. Slave cylinder went bad, $29.00 later she works like a charm.
S13FASTBACKSR
I have no idea what the topic starter's problem is because he confused the shat out of me but yes if you cant get into gear it is most likely the slave cylinder. also putting in transmission fluid is easy..on the driver side of the transmission you will see where to put it..take out the bolt and then pour in the fluid and when its seeping out you know you have enough
garagelu
Car: 1995 240sx w/ sr
when your changing your transmission oil its so much easier to drain it through the bottom and then take your shifter out and refill through the top. Refilling through that side hole gets you in a cramped spot and it takes forever to do it. At least it did for me.
corey240
is it safe to put it in through the shifter? or does it even make a difference?
S13FASTBACKSR
ya it seems like a good way to do it and much easier..only unsafe thing about it would be taking the chance of spilling oil on your interior so just be careful
IanS
also, Ive never been able to put in as much as the FSM says, so I open the side fill and then fill through the top till it comes out the side, so I dont overfill
S13FASTBACKSR
so you put the oil in from the shifter too?
