erick240sx »
https://forums.nicoclub.com/erick240sx-u216542.html
Mon Mar 11, 2013 2:01 pm
Got my car back from the mechanic:
Things that are obviously wrong with. They cant even run a diagnosis before i fix these things.
EGR valve is missing a vacuum
Needs Intake air temp sensor
The charcoal canister has a broken vacuum port.
Exhaust gasket to converter leaks
My question to you guys is, is it worth $700 to fix all these things, or is there any cheaper way to do it?
Is there any way that i can fix some less complicated stuff myself? I read that the EGR is best left alone, and to take it to a mechanic because its pretty hard to get to.
1990 240sx SOHC
