Intake Air Temperature (IAT) Sensor KA24E Bypass
rocksteady_racer
Car: 90 240sx Hatchback (Manual - boosted soon KA24e)
Ok so I put an intake on my 90 240sx but there's no spot for the intake air temperature sensor. There's a way to bypass it right? I've heard it's 4.7k ohm resistor and you just jam it in the from ecu connector then right?
I'd just leave it unplugged but it advanced my timing a little bit farther than I expected with it not plugged in. Thanks in advance.
Or should I just plug it in and zip tie it to the side of the intake pipe?
My intake plate still has the hose connector to that emissions box so I was thinking about mounting in there as another option but I thought bypassing would be a little easier.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Keap it plugged in and zip tie it off to the side. Problem solved.
2hunglo1standhi
Car: 1990 240sx XE Coupe KA24E-T
1990 240sx SE Fastback KA24E N/A
You really should drill / install it into the intake tube. It will run fine off to the side but you would get a more precise reading of the temp your engine is getting if its installed in the tube, and not effected by under hood, engine heat factors.
