"wink"
Here's a rough list of what's in the car..
S14 SR20DE (non-turbo) motor/transmission 86.5mm JE 8:1 C/R pistons Saenz custom connecting rods w/ARP bolts Nissan Motorsports heavy duty main bolts ARP head studs Nissan bearings HKS 264* cams HKS springs/JWT retainers Mild head porting (bowl area and short side of runners) New valvestem seals/guides Cometic metal headgasket Blue-printed/assembled in-house
T61/P-trim turbocharger FI-R log manifold 3" alluminized downpipe HKS 50mm wastegate 2" dump-tube (atmospheric) Griffin intercooler core with custom end-tanks (fabbed by PSI Racing in New Orleans) 2.5" and 3" intercooler piping (powdercoated silver) 3 ply silicone connectors and double-clamps on all connections FI-R fuel rail 107lb/hr injectors (880cc's at 57psi base pressure) Stainless steel fuel lines (Twin -4an feeds) Aeromotive regulator (setup for twin feed) Twin 5/16" feed lines from tank Twin 255lph Walbro HP pumps 3/8" return line to tank NOS Direct Port fogger kit NX Bottle heater and pressure switch Electromotive TEC II stand-alone (3 bar MAP) Greddy Type R blow off valve Autometer Boost, EGT, Fuel pressure and Oil pressure guages in custom mount where A/C and radio used to be Switched power to all accessories from Dash panel Custom MSD 8.5" Magnacore wires Greddy Profec B Spec II boost controller JWT alluminum flywheel and Z32 clutch/pressure plate Welded rear diff Cryotreated axles/hubs Mickey Thompson 24.5 x 9" slicks Bassett custom 15" x 9" steel wheels (for slicks)
I am going to the dyno next week... Hoping for anything over 600whp on the spray.. Wish my luck!
Travis
