ChunkiDori wrote:You know, I could be wrong, but I could swear that NA S14 SR's did not have the VTC solenoid on the intake cam. It looks like you have a DET head on a DE bottom end maybe?
edit: and if it is a DE head, it wouldn't be a CAS block off plate, it would be a stock distributor blockoff plate. Only the RWD DET uses distributorless ignition. If it had a CAS when you got it, then you know what you really have.
Morph wrote:Yo whats your address. It says that PMing is disabled
TurboB15Sentra wrote:Nah.. N/A S14's did have VTC too. It's a DE motor for sure. It's got the smaller valvestem seals.. meaning it's got non-sodium filled valves. This only came on DE motors. It had a distributor too.. Sorry, I called it a CAS block-off plate. :-p
Travis
TurboB15Sentra wrote:The S13 head has a better flowing port design.. The ports are shorter, and flow better at higher RPM. This means that it will make more peak power. The ports on the S14 are smaller and longer.. meaning that low/midrange RPM power is a little better.. but top end is sacrificed.
Travis
