dave230 »
https://forums.nicoclub.com/dave230-u89323.html
Thu May 08, 2008 4:33 am
I test fitted my 14' kayak on the standard roof rack today... I figured it was going to present some problems, and sure enough it really does. I'm off to the Yakima dealer shortly.
I had a 2002 Pathfinder before this car, and I really have had no problem making the transition... love the Rogue. However, you could build a house on the roof rack on an SE Pathfinder, and the same can't be said for the Rogue.
Number one... the cross rails are way too close together. I tried using my J-cradle kayak holders and gave up immediately. The widest part of the boat sits in the cradles and the boat will not lean back at all. Extremely unstable, and I wouldn't dare to even drive it down the street with that setup. Again, on the Pathfinder I had nearly five feet between roof rails... what a difference!
OK, tried my foam blocks that wrap around the cross bars. Somewhat better, but due to the shape of the roof, the boat was tipped way up in the front. Still no good. I got a knife out and shaved two inches off the front foam block and got the thing about level. Looked better, but still very shaky due to the short distance between cross bars.
Tied it down and out on the Northway for a quick test. At 65mph the boat was vibrating and moving all over the place. The whole rack moves with it. No way this would be safe.
And then you have to take the front license plate off to use the tow hook to tie the front down, which would insure some pleasant conversational time with the state troopers up in the Adirondacks... and the strap or rope is going to rub all over the rounded hood as well.
There is so much flex in the factory rack that it really is unusable. I get the fact that the crossbars are positioned away from the sunroof, but on the Pathfinder you could adjust them and bring the front crossbar all the way forward while using the rack, and then quickly slide it back past the roof when done. That rack was fantastic, and this one is worthless as is.
I'm hoping the Yakima stuff will be the answer, but it's too bad that you have to spend three or four hundred dollars more just to make the roof rack usable on what is loosely marketed as as at least sort of an SUV.
Don't get me wrong, still love this car, but there are times when you realize that it really is a car and not the truck that the old PF was.
