Solved issue with backup lights and transmission not shifting outta 3rd...
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
A month or so a go I finally fixed the back up light issue.which in turn fixed the transmission..
Ill explain...
My back up lights would blow out if I put my Q45a in reverse for more than 4 sec. if the fuse blew then the transmission would not shift see these two threads for details:
zerothread?id=101555
and
zerothread?id=97760
I found that the wire harness that runs to the tail lights along the trunks main supports had been pinched by the trunks lift stoppers and the trunk lid support arm. This had severed all the lines in the harness that run the into the trunk lid..
So all the wires were exposed to the steel of the trunk lid support arm.
I traced all wires in the harness back two feet and found no other signs of damage..
So I trimmed the bad burnt ends off stripped them and SOLDERED and HEAT SHRUNK Each and every wire in the harness. Tested... no more blown fuses.
Just a follow up..
I will post pictures as soon as I download them from my better halfs Samsung P735 (1.3 Megapixel camera in a phone) it takes great pictures.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Great news jeremy! I had the same problem on my Q before I owned it!!!
