In response to you my friend, good luck with that project!ks13 wrote:Ahhh i was waiting for you Dee, and I did explain my reasons for a 9k limit.
I have everything needed minus solid lifters and rod bolts at this point.
I know of a local sr20 with its gay inferior rocker arm setup revving for a 9k limiter, It never hits the limiter.....thats what Im after.
You make it sound like the most impossible thing to do, but I bet with some uprated springs the stock hydro lifters would be up to the task with some mild 256 cams.
If I said something like 10k, than Id expect that kind of response from you. C'mon, you should know how strong these engines are.....8:1 pistons to boot, that gives me cushion for pushin right there.
Modified by ks13 at 8:40 PM 11/22/2007
Didn't know Eagle makes rods for the CA .sldwys wrote:I have myself some Tomei 272 dur 10.25 lift in/ex cams for my Ca, Coupled with Solid light weight tomei lifters, Tomei shims, Tomei Valve springs. New over sized valves, Tomei camgears, Tomei metal headgasket, Eagle rods and CP pistons.... Head ported to hell and i also had to shave some of the head away to get the cams to rotate around without getting any contact.... Garrett gt3540 Duall BB turbo, W/G, Alloy intake manifold, q45 T/b....
I reckon i could hit 10,000rpm..... well... maybe 9500 rpm anyway
Tomei sells those lifter shims in packages of twelve.....all different sizes.sldwys wrote:I have myself some Tomei 272 dur 10.25 lift in/ex cams for my Ca, Coupled with Solid light weight tomei lifters, Tomei shims, Tomei Valve springs. New over sized valves, Tomei camgears, Tomei metal headgasket, Eagle rods and CP pistons.... Head ported to hell and i also had to shave some of the head away to get the cams to rotate around without getting any contact.... Garrett gt3540 Duall BB turbo, W/G, Alloy intake manifold, q45 T/b....
