Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Thu Nov 01, 2007 1:34 am
Maybe I'm behind times or just over looked the information somewhere but thought I would maybe bring light to the subject. I just personally found out that...
Tomei lists the soild lifter set under the same part number for the following:
VG30DETTCA18DETRB25DETRB20DET
RB25,20,VG30,CA18 Solid Lifter- Use when exchanging hydraulic lifter to the shim adjusting system- Must use solid type camshaft- Height of the base: 1mm- Small base circle diam: 29- Corresponding to the TOMEI camshaft of 9.25mm or 10.25mm lift- High strength by cold forging lightweight model approximately 35g (STD 57.5g)
For those who want to run 10.25mm lift cams there you go. I remember there being another xreference to another set or vehicle but someone would need to fill that in.
