SOHC to DOHC swap and wiring
oldskoolracer
Car: 1989 240 soupe
i have a blown motor 89'coupe and i also happen to have a good dual cam but this is a swap i haven't ever done before any suggestions or links that could help would be great
i thought about an sr but i want to see what i can get out of a ka-t first
then we'll go from there
Modified by oldskoolracer at 1:14 PM 11/9/2005
oldskoolracer
Car: 1989 240 soupe
some one please don't hate please need help
nismo_s13_1990
Car: datsun 280zx
from what i have read/learned the motors are a simple swap. depending on what year the dohc motor is determines the simplicity of the swap. 91-94 are virtually plug and play. 95-98 will need a hybrid wiring <phase2motortrend.com> offers this service for $350 but you must send them the sohc and dohc harnesses unmolested. from what im not sure but if you have the ecu for the dohc of a 91-94 you might have to swap them as well. once again i haven't done this my self but do let me know how it goes because i am soon to install a 91 dohc w/ ecu and wiring harness my self.
mirra32
zerothread?id=115651
i've done it...same crap for 91 and up ka24de motors
coupebuddy
Car: 89 coupe 96 motor 93 harness 91 auto ecu cai,msd,plug wires,12v charged ignition,hyper grounded,stru
If u use 91 to 94 u must also use dohc plug to ecu behind dash by the ecu. u can use 95 + motor but only w 93-94 harness besides that plug by the ecu its plug & play and u need to change the tach in cluster
frapjap
'07 Subaru Legacy
Look for a thread titled "SWAP! KA24e to KA24DE"
If you don't find it there, look for topics I personally have started and look for it. I did a pretty thorough write up when I did the swap two summers ago. Its got everything you need from a parts list, wiring, step-by-step instructions, and trouble shooting.
Good luck, its not to hard, but give it a shot. You can always email me at [email protected] if you get a hiccup.
