Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Jan 31, 2008 10:42 am
The car would run a funny Air Fuel mixture. MAFs work by seeing how much voltage is required to keep a heated element a certain temperature. The more air coming through, the more voltage required to keep that element at its proper temperature.
When you hear of someone "maxing" their MAF, they've basically hit the limit of what the MAF can do as far as keeping that element heated.
Z airflow meters work in the same way, but their voltage readouts mean different amounts of air are coming through over the SOHC/SR MAF. IIRC, more air is metered by the Z MAF per signal voltage.
The ECU is used to x-amount of air coming back for z-voltage signal. Now all of sudden it's still seeing z-voltage, but y-amount of air is coming through. The motor's air fuel mixture gets all whacked because the ECU meters out gas based on that voltage signal. IIRC, the motor runs lean to the point that you can't get it to idle for sh1t, let alone actually run. Heck, I think the computer might drop the car into limp mode now that I think about it.
the above is the same for DOHC MAFs as the signal they send back means that a different value of air is actually coming through. The difference isn't as drastic though because the DOHC and SOHC MAFs aren't as different as a SOHC and Z MAF
