so you want a CHEAP(IE FWD) vq35de in your 240sx???
Discuss topics related to the VQ series engine.
PhillyDaKid-S13
Car: 1990 Nissan 240sx XE coupe, sold...(sniff)....1991 240sx fastback project, YEZZIR!!!
actually, i may have found a way to bypass needing that gaugue cluster (altho I still may just do it, just because it looks so baller...lol
ive been doing a LOT of research on this swap (seeing as tho the hospital I work at is closing, i have a LOT of time on my hands now, lmao.) the vq30 heads from the pre-2002 maximas, as well as its non variable cammed timing equipment, can be used on the top of the vq35 block for this swap, and is actually done regularly by maxima owners who swap vq35s for their vq30s. ive even got a guide that shows you how to do it. so this is the route im going for this swap. so now, IRAX!!! wuts up with those mounts? i will be needing some this summer, so whats the status regarding their availability?
PhillyDaKid-S13
what i DO need to know tho, is the compatibility of the 350z intake mani for the vq30 heads....anybody got that info?
irax
Car: VQ35DER Powered S14.3
the manifold will fit but it wont line up perfectly with the bore but it will still make a good enough seal to run, IIRC broaner the first guy in the us to swap over a vq30de-k into a 240sx used a 350z intake manifold.
I know i don't check this forum enough anymore been way too busy actualy learning software to build my website
if anyone ever has a question they can email me at ibsemailis(AT)gmail(dot)com yeah its annoying but i hate getting spam
or myspace.com/trouser
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
IRAX do the stock 350z cats fit on the 240? I'm kinda leaning to this swap and busting my a** to get it bared.
irax
you have to rotate the flange on the exhaust manifold and shimmy it a little and it will fit fine.
also feel free to hit me up on aim NismoS134
vqpwrd240
Car: 93 S13 and 97 Maxima
The VQ30 and VQ35 have different intake ports. If you want to use the Z33 intake manifold you need to use the lower intake as well along with port matching the heads on the VQ30 engine.
Ferhan
wells596
Car: 97 nissan maxima
I own a maxima with this motor in it, anyway possible to convert my fwd to rwd with a 240 trans?
Anything is possible - with enough fabrication.
You're going to need a front and rear subframe from a RWD car, you're going to need a solid understanding of suspension geometry, and you're going to need to be one hell of a fabricator.
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
