PhillyDaKid-S13 »
https://forums.nicoclub.com/phillydakid-s13-u52503.html
Tue Jun 02, 2009 12:00 pm
Hey irax. wanted to get a hold of you because Ive decided that Im definitely going to be going vq for my swap. When do you expect to have these motor mounts ready for sale? and also, you said that that rwd drive (ie g35/350z) intake mani is necessary. is it a direct bolt on to the fwd heads or will it have to be modified? instead of going through all the trouble to get a speed signal, ive been following a vq35 into s14 swap over at my350z.com and that guy custom mounted a 350z cluster (which can be had for dumb cheap on ebay) into his dash, i will go the same route to avoid the trouble, just wanted to put that out there that thats also an option. IPDM, what exactly is that? and which smog equipment from the donor car is necessary (egr valves, etc?) Ive also noticed that the 350z trans bolts right up to the ka trans mounts, does your swap kit also provide this convenience? and last question (i promise!). a couple of the swaps ive seen had trouble with the starter because of engagment issues with the flywheel. have you ran into any trouble with this, or is this something thats dependent on parts used, etc? what I eventually plan on doing is compiling a vq->s13 thread because there is a LOT of interest in this, but not a lot of info in one place, and ive come across a LOT info, including a way to bypass the NATS system (possibly) and a remedy for controlling the variable timing on the vq35 (again possibly....). in any event, love to hear what you have to say on my inquiries. thanks.
