Imissmyturbo wrote:Well I found a rather large exhuast leak before the turbo at the inlet flange. If I put my hand under there I can fell Air leaking out. Getting that sealed up will make a pretty big difference in spool time and throttle responce.I took the car out on th Hyw for the first time and I must say it feels really strong is 3rd and 4th gear for only running 5 psi! The higher I rev the harder it pulls.My wastegate will be plumed back into the exhaust a good 2 feet from the turbo outlet. I plan on putting it in at a 45 degree+ angle to keep cross flow to a min.
Imissmyturbo wrote:Well I got the exhaust leaks fixed. What a difference that made! The turbo was loose on the manifold. No wonder it laged soo much. I can't beleave it even mabe boost. It feels pretty good for just 5 psi. I plan to try 8 psi and maybe 10 if the A/F looks good.
Imissmyturbo wrote:power band is great! shift from each gear near redline puts you at the right spot for each gear! Car goes through 3rd and 4th gears pretty quickly.
Whats so funny yellow4G63?
emperor_lunchbox wrote:I want to be able to hear the engine and sounds and stuff like that but I dont want to wake the dead...
