Looneybomber wrote:What happend there?
I got laid off when they were closing a bunch of the stores. A bunch of installers got laid off
It's alright, I stopped in the local soundadvice and almost all of the salesmen are in draw(not making money basically).
audtatious wrote:
Looking for a DVC-4 sub (parallel 2ohm config to handle 400w) that works with a 1.25cf sealed enclosure. Huge xmax is not necessary, but I want it to be able to go low while still being able to handle a 75Hz crossover point.
I am going to recommend the TC Sound TC9. It's not an spl monster, but it will give you exactly what you're looking for.
When graphed it has more output down low then the 12w6, and is flatter up top then the W6.
Also, the TC9 has a higher motor force.
It does handle 800 watts, but that doesn't really matter. The excursion on it is 18mm. Looney can probably verify the Xmech, IIRC it's in the range of 30mm. So you won't be bottoming this driver out .
Oh yeah, and it's cheaper
