audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sun Jul 01, 2007 8:13 am
So.....Decison time....
I'm working on my new enclosure and need to determine what sub to run prior to laying 'glass. I have two to choose from: TC12 or Kicker C10a
Both require the same amount of air volume. Obviously the 12 will have more "punch" and will pull 400w (2ohm parallel) off my monoblock whereas the Kicker will only pull 200w (4 ohm). So, right there we are looking at -6db down (less surface and 1/2 watts).
The issue I have with the TC is weight. It weighs 30lbs where the C10a weighs 6lbs. Weight is my enemy in this car as it is. I weighed the original enclosure I had and with the sub, amps and caps it weighed in at 95lbs . The box I am working with currently weighs 12lbs by itself without the 'glass. Conceivably, with the Kicker sub, amps and caps it could weigh less than 40lbs easy. The same box with the TC would weigh at least 60lbs+.
The Kicker is a good little 10". It's the old-school sub that I picked up in '96. If I decide to not use the TC, it will begin new life in my current home sub system so it's not a loss.
Decisionse....decisions.....
