so no t25 is not a direct bolt on
CaEric
Car: 91 Sr Pwred Coupe
Well it is and it isnt.....u have to some how clock the compress housing a lil...can anyone give me an idea as to how i do that ...do i need to mess with inner c-ring clip ?
kapower06
My t25 was a direct bolt on. Its just been ported and has bigger wheels.
Anywho Yes. you will need to either compress the C-clip or loosen up (loosen NOT remove) the bolts the hold the turbine housing to the CHRA then you will be able to rotate the compressor housing and CHRA as one assembly, but only a lilttle, make sure you do not bind the wastegate actuator.
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
did you search? or even look at the threads on the first page? i only ask because this was just recently covered and is still on the 1st page.
zerothread/197717
SR t25? thats what i used. i tried to c*** mine and it would not budge with the ring compressed,removed and with a rubber mallet banging on it. i tried installing it without cocking and it was fine.
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
yourmomsrps13 wrote:SR t25? thats what i used. i tried to c*** mine and it would not budge with the ring compressed,removed and with a rubber mallet banging on it. i tried installing it without cocking and it was fine.
were you able to reused your old lines or did you go SS lines?
yourmomsrps13
used all the old hardware
float_6969
Make sure when you guys are clocking these turbines (if it needs it) to clock the compressor housing only. If you clock the center section too much, you won't be able to get your oil inlet back on because it'll be too close to the turbine flange.
dvd
personally I just got some stainless lines, makes things much easier.
davidricardo86
Car: 1992 Nissan 240SX SE
Stainless Steel lines huh? On average, how much do these run? .... so lazy
dvd
takamotorsports.com i think 180 for all the lines? Be sure to tell him that its for a ca18det because the oil feed from the block is different than the sr one.
CaEric
they sell the single oil feed line at takmotor..u have to use the s14 ones....i test fites tehm at a buddys shop and the fit snug.....
