So it wasnt the transmission...hmmm
DALAZ_68
Car: 90' 240sx CA18det
well what about the clutch disc? does it look like it was installed wrong? or was it even the right one...?
i saw a number on the disk, it said 225LTD on it, and theres 2 other sets of numbers on it...cant remember right now, and i cant see the pics at work...
one set of numbers was 225 LTD and it had NISSAN stamped as well near it and on the other sid eit had this number 44F04 GH and stamped VISIUN
Modified by DALAZ_68 at 1:45 PM 4/5/2010
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
whether or not it was installed correctly, it is currently f***ed. Get new one, install, done.
DALAZ_68
agreed...my thing is (and i know i still need to post pics of it) the side that still has solid material on it is the side facing the flywheel, yet, its that side that dug into my flybolts...so im left wondering...if the flywheel needs replacing or not.
so it does matter in a sense whether the clutch was installed right, or if it was the wrong one...etc...
pretty much determines how much im paying here in the next couple of weeks to make my next event...
r34 gtr
Well, lets see this flywheel then!
DALAZ_68
r34 gtr wrote:Well, lets see this flywheel then!
r34 gtr
That clutch had to have been installed improperly, look at the gouges on those flywheel bolts!
It would probably be okay to have it resurfaced. Give it a shot - the machinist will let you know if it is too far gone.
DALAZ_68
from what i can tell it looks like it too has hairline fractures, but the camera didnt get it very well...its gonna come off this weekend...if anything ill do Jun flywheel, Spec stage 2 or 3 clutch and call it a day...
croustibat
Car: 200sx S13 w/ ca18det
You can also get an XTD chromoly flywheel (they are dirt cheap, find them on ebay, aimcoclutch seller) and a spec stage 3 clutch. I bought the stage 3 XTD flywheel & clutch kit and had it delivered in France for 350$ if i remember correctly.
but i dont mind changing them again in 30.000km as the car will not be driven a lot.
I know spec clutches are up to the job. a friend of mine has a spec stage 3+ on a 400++ HP CA, and it worked very fine for a long time (hes blown the engine and rebuilding it, but keeping the same clutch)
DALAZ_68
the more i hear about spec and there stage 2-3 clutch the more i feel comfortable to actually buying it...as far as the flywheel the Jun FW looks to tasty to pass up...that, plus ARP bolts...i think i should be fine...
r34 gtr
Yep, you should indeed be fine.
zero_gripS13
Car: soon to be 95 s14 hopefully
well i have a ka clutch on mine. ITs made custom by this guy who started with corollas.. Called illegal Garage. its dual diaphram and copper/kevlar disc. it was around 400$ and takes last 3 years of drifting like a champ. 3rd gear clutch kicks and all :P. seen a few specs blow up.
DALAZ_68
so heres whati ordered, let me know what you cool cats think
Jun flywheel+ARP flywheel bolts+SPec Stage 3+ alum single piece drive shaft...
=SEXy
r34 gtr
That is pretty sexy.
Modified by r34 gtr at 1:23 PM 4/12/2010
DALAZ_68
should i be worried about any torque loss...?or should i beworried aout how rev happy this thing is gonna wanna be...lol
r34 gtr
I think you need to be more concerned with how ballin' outta control your car is going to be.
DALAZ_68
so my supplier cant get neither the jun flywheel nor the clutch...(F$(^$(&*^$*(^&#@#@*(#*@)&@)K!!!!!!)
so he sent me this linkhttp://www.competitionclutch.c...d=300
^ anyo f u guys heard about these?
i guess ima order the jun flywheel from the link provided earlier...sadly its still coming out to roughly 500 bones due to shipping... FML indeed
DALAZ_68
found this on Ebay though...
http://cgi.ebay.com/ebaymotors...57257
r34 gtr
^ Pull the trigger on that JUN stat.
Ca_Silvia
Try RHD japan they have obscure CA stuff sometimes
DALAZ_68
yeah i was contimplating doing this actually...http://www.rhdjapan.com/checkout/cart/?product=1/
DALAZ_68
Clutch Dischttp://www.rhdjapan.com/nismo-...59660
clultch pressure plate...http://www.rhdjapan.com/nismo-...59658
any thoughts
Modified by DALAZ_68 at 4:12 PM 4/13/2010
Jables
Car: 1995 RB26DET S14, 1991 RB25DET S13, 1992 S13 LS1 Coupe
Edit for not seeing you already bought... You still have my contact info if you have any problems...
And i have flywheels on the shelf if you run out of options!!
Modified by Jables at 2:37 PM 4/13/2010
DALAZ_68
r34 gtr wrote:^ Pull the trigger on that JUN stat.
DONE...shipped...
Jables : damn you...LOL...i bought the FW already...check ur email...i still need clutch and ARP bolts...
Jables
You have mail sir!!
DALAZ_68
sweet so now i just need to source my ARP fw bolts, my usual parts supplier couldnt get me anything...lol
DALAZ_68
so...while i was searching around the net last night, i cam up on a thread talking about how, using the JUN flywheel...the Flywheel bolts are...to short...by about 1/2'' ...?
http://www.240sxforums.com/forums/ca18d ... -hope.html
^ see thread above...
im planning on running ARP bolts...but wouldnt i run into the same issue if ARP when made to OE specs...just stronger material?
ideas...?
Jables
If you can figure out what the exact measurements are i can special order you some crank bolts that will be perfect..
DALAZ_68
what sucks is i think ima have to wait till the flywheel i order gets here...this way i can measure the different lengths pertruding thru it and measure out the difference...and figure out the thread pitch...sigh...
DALAZ_68
since i cant seem to see an Edit button on the new system here at work im just posting up another reply...
CA18DET Flywheel Thread pitch seems to be M10x1.0... confirmation?
now i just need to verify proper length...
Jables
Cool... Just let me know length and ill see what i can get them for asap!!!!
