Chad... Congrats on finding such a nice Q... VERY rare to find a 90-93 with the guides done... GREAT find!
1. Ill check my manual but I seem to recall you just pop them out... Maybe Im thinking about the front ones but I cant remember off hand... Like I said if someone doesnt chime in Ill check the manual to be srue...
The tail light inoperative message: I hate this system on the Q... Most of the time it can be fixed by using OEM bulbs, which can be had from one of our fine sponsors at the left. I prefer everythinginfiniti... Call 18882165328 and talk to Joe, and be sure you tell him your a NICO member!!!
Anyway there are sensors that detect the amount of current draw from the bulbs..... When its out of spec the computer reads they are not working, and most times can be eliminated by using the OEM bulbs because osme after market bulbs draw different amounts of power.....
2. This is common and there is a sensor on the pads that detects when they are worn, unfortunately when they get that worn they are much passed their designed life... Most members here bypass them by shorting them out (twist the wires together..)
3. You can get them from ebay, from a 2000 and up Maxima... Check out
http://www.q45.org (mine and Jesda's website) for an article on how to do this. I ahve it on my Q and it put me out $25, which the next best thing is the stillen for $100..... For the results it gave me Im glad I didnt spend the $100!
4. Easy fix. I did a writeup sans pictures, but basically what you gotta do is take out the antenna motor (3 bolts just behind the passenger side trunk cladding), get out al the old belt and reinstall a new mast... Search for ANTENNA MAST. PRoblem is after a long time the nylon belt on the mast breaks.. Theyre like $10 from Joe and it took me 30 mins tops to fix.....
5. OIf you keep all the fluids fresh (oil, transmission, PS, brake, Diff), add a transmission cooler (which has been done), and keep up on maintenance you should be good... What kind of service history does the car have..... You may be ready to do the 60k service (air filter, fuel filter, spark plugs [which i sell], etc)... Later you may be interested in doing the plenum and changing the hoses and knock sensors [which i sell]/harness... Making sure this car is running tip top is the key..
ANother thing you may consider is a 93 or 94 TCU to eliminate the 2nd gear start of the 90-93 Q.. The 93 has the first gear start with your transmission, and the 94 does as well but there are different gera ratios, but Ive heard from members that a 94 TCU works great with a 90-93 trany and ECU
6. Upon reading the previous posts (you HAVE done that, right?
) youll find that the intake and exhaust, especially the intake are as optimized form the factory as you can get... Treat yourself to a new OEM air filter every year and be happy! Dont do any intake mods EXCEPT those board approved (read AZhitmans CAI mod)... Ive done something similar to AZ except on the front air horn my piece of cladding was missing so its right in the high pressure area... Not as effective on the 90-93 with the grilless design.. id say leave it be and dont fret about a 1HP (max) difference youll get!
BRM and AZhitman have made a full stainless steel exhaust system for the Q and its mighty golden..... However upon further reading youll find the stock is VERY high flow and basically the only restrction is in the rear resonator and that can be easily upgraded..... not to knock on BRM exhaust or anything, but I personally dont see the need to spend $700 on somthing youll get the same improvements for $300 by just changing the rear resonator... It may sound better and if thats what your after, by all means..... Not what I would do to my Q though!!!!
Welcome to NICO!!!!
